cswinford
Jul 19, 2016Explorer
Jim-Linda wrote:
If it was flooded, first, I would remove converter and dry all water, check all fuses or breakers on the converter itself. If ok, I would disconnect the output and apply power to converter. If still ok, turn breaker off, connect multi meter to output and check reading. If no reading, converter is defective.
Thanks, Jim-Linda
It was necessarily flooded because the top of the converter is not open. It's a Progressive Dynamics unit and the only openings are on the ends. I did not unplug the unit but I did dry up around it and put a hair dryer on medium heat on it for about 15 minutes. I'll take the next steps you mentioned, but I don't have a multi meter with me.
About Fifth Wheel Group
