neversatisfiedjExplorerFeb 19, 2014Converter in sandpiper 365SAQHow do you test the converter ? I think it may be bad. My 12 volt source keeps dying out. I can only keep it going with a battery charger attached to the battery. I have not tested the battery cells , though the battery is almost new.
1 ReplyReplies sorted by Newestdonn0128Explorer IIFeb 19, 2014Disconnect the two leads from the converter then using a volt meter take the reading at the converter. It should read approx 13.66 VDC
Related ContentNew Sandpiper 365SAQConverting two 30amps to one 50amp for RV campingNo 12 Volt without converter80 amp converter and eu2000iSandpiper
