drae0814's avatar
drae0814
converter noise
Hello,
Full timers we are new to the full time life and still learning. My converter is a little loud some times and the lights flicker the converter makes a hum and sometimes loud pitch noise. I checked the batteries all good. Is this normal or is my unit about to go out?
Thanks for your help
  • Might help if you posted the made/model of your converter. My original old Magnatek converter would often make noise - sometimes fan, sometimes just humming. I replaced it with a Progressive Dynamics converter which has always been dead silent.
  • The first indication that my OEM converter was beginning to fail was the flickering of the lights....and then we noticed that the battery wasn't charging very well.
    I carried a spare until the converter gave up the ghost - while on a weekend trip. Had to use the truck hook-up to bring up the landing gear.
    The swap out was pretty easy.
    You may want to order the replacement until needed.
    Good Luck
