SpurHntrExplorerOct 08, 2013Converter trips receptacle gfci help needed...Rig in sig below. Converter is a Parallax 7355 Using a 15 to 30 A adapter from a 25 ft extension cord to the campers 30 amp cord: Plugged in to a 15A gfci receptacle with non gfci breaker. (Conv...Show More
ScottGNomadOct 08, 2013Are you sure the fridge isn't on the circuit? They are the most common cause of ground faults.
Related ContentNo 12 Volt without converter80 amp converter and eu2000iProper Power Receptacle For Home?Solar needed?pedestal receptacle
