time2roll
Oct 08, 2013Nomad
GFI might be overly sensitive and converters are known to leak current to ground/frame/negative. Might try a new or different GFI.
Time for a bench test. May need to put a plug on the converter to test.
Either way you battery(s) would appreciate a new PD4655 if you are inclined to upgrade to a three stage converter.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
