Matthew_B
Apr 21, 2011Explorer
Ductape wrote:
Part time operation unless you need the traction is a good idea. IIRC there were some Fords back in the 70's with a divorce mounted full time transfer case. NP203? If so a 203 may or may not be up to what that Cummins will send to it.
You can still find divorce mounted NP-203 cases. The worry would be that the case uses a chain for the front drive. The divorced cases are all the pre-77 models that had more problems with jumping chains.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
