Matthew_B
May 10, 2011Explorer
Securiti wrote:
I will accept almost all this. It is hard to believe a 5000 pound truck camper puts no weight on ft axle. But if you say so. I will try to believe.
Pretty much. With full fresh water and empty waste I add 200 lbs to the front axle. Empty water and it is balanced over the axle. With full waste tanks I take 150 lbs off the front axle.
Securiti wrote:
And as for my 3500 pounds. That is empty. Now add in 160 Gallon of water. (Tank is in front) Add in 4 propane bottles. Add in the extra 125 gallons on diesel fuel in the bed tank. Etc: I think I am over your 5000 pounds.
Well you should have said so :W
What is it when you put toys in as a counterweight?
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
