- SoCalDesertRid1Explorer IISecuriti,
Even though tandeming the truck is not how I would have gone about increasing the trailer towing or hitch weight hauling ability of the truck, it is an interesting and fun project none-the-less that I will follow as it progresses here on the forum. I lend my support to the idea. :) - SoCalDesertRid1Explorer IIDuctape,
The NP203 is full time but can be converted to part time. It is a 2-section transfer case, one section for the range box (low gear) and one section for the f/r driveline split. The 2 sections of the t-case can be separated and used independently. It is common for rock crawlers to yank the range box section from an NP203 to use a 'doubler' in their drivetrain, since the 203 has a 2:1 low range. The NP203 and NP205 were made in the 70's and both have heavy duty iron cases and can handle quite a bit of torque output from the engine. The 205 is an all-gear part time t-case. The 203 uses chain drive with a center differential for full-time operation. - DuneJunkieExplorerthat is a huge project to take on, great work, gonna be bad azz when its done!
for sure it is orginal, and the best parts is that YOU did it.
You could have just went out and bought a semi or something, but nope, you built something.........pretty awesome man! - stsmarkExplorerThis is awesome Securiti, I applaud you for taking it on. You might consider an Atlas 3 transfer case as they are darn near indestructible. Price might be an issue. We run one in our Cummins YJ rockcrawler.
Damn the torpedoes, full speed ahead!!!! - gravessatExplorerhttp://www.youtube.com/watch?v=TonDLE3akz4
- The_TexanExplorer
btcruzer wrote:
Some people are sheeple and then some like Securiti are thinkers and doers. I would only hope there were more thinkers and doers then sheeple, but it won't happen as demonstrated by your negative post.
I can think of only twenty or thirty easier ways to accomplish the goal. - jetboater454ExplorerThat explains why you didn't have time to stop by when you were down this way.Had to get home to start that.Looking good.
- Clanton24VExplorerlooks good. i remember when the dodge T-rex concept came out i t was pretty sweet IMO. i know some have made their own versions of it and have used the Rockwell 2.5Ton axles. keep up the good work
- gboppExplorer
Securiti wrote:
Kepler4 wrote:
How about posting 2 or 3 of those in detail.
Great project Securiti! You've got more guts and fabricating talent than I.
Thank you. It is nice to hear posative comments. I am not sure what to think about the negative comments.
Don't worry about the negative comments. I'm sure we all wish we had your ability. I know I do.
Continue with the good work and keep us informed. It's an awesome project. - SecuritiExplorer
About Fifth Wheel Group
19,038 PostsLatest Activity: 4 days ago
