- SecuritiExplorer
Crazy Cooter wrote:
Something useful I found recently: http://www.roscommonequipmentcenter.com/eng_calc.html
I think you have plenty of axle capacity for what you are planning.
Nice link!! Thanks. - SecuritiExplorer
TugCE wrote:
It would still be a good idea to head over to a scale once you get her all finished. This way you will know right where you stand.
Will do for sure. Thanks. - Crazy_CooterExplorerSomething useful I found recently: http://www.roscommonequipmentcenter.com/eng_calc.html
I think you have plenty of axle capacity for what you are planning. - TugCEExplorerIt would still be a good idea to head over to a scale once you get her all finished. This way you will know right where you stand.
- SecuritiExplorer
rehoppe wrote:
Don't forget to watch your front axle weight. Diesel, extra 115 gallon fuel, sleeper and contents. Might get heavy. That'd entail early repair on front end, probably mostly bearings and rotors.
YOu might be able to shove your hitch back to unload a bit of weight off the front IF necessary. Backs up better, as well.
By the looks of tag. It looks like I should be fine.
- rehoppeExplorerDon't forget to watch your front axle weight. Diesel, extra 115 gallon fuel, sleeper and contents. Might get heavy. That'd entail early repair on front end, probably mostly bearings and rotors.
YOu might be able to shove your hitch back to unload a bit of weight off the front IF necessary. Backs up better, as well. - SecuritiExplorer
TugCE wrote:
Man, that is going to be a towing beast! I like the idea of maybe putting a wing on the cab roof. With the bed I think you are right a flat bed or better yet build your own hauler bed. Either way you are going to have some truck when you are done.
Thank you. I dont want something better. I just want something that will do the job safely. - TugCEExplorerMan, that is going to be a towing beast! I like the idea of maybe putting a wing on the cab roof. With the bed I think you are right a flat bed or better yet build your own hauler bed. Either way you are going to have some truck when you are done.
- SecuritiExplorerThanks for the input guys. I think I will use your advice on contouring the roof line. And useing a flat bed. This hasent been an easy task. But there is nothing like building your truck when its all done. Again. Thanks for input
- rehoppeExplorer
The Texan wrote:
btcruzer wrote:
Some people are sheeple and then some like Securiti are thinkers and doers. I would only hope there were more thinkers and doers then sheeple, but it won't happen as demonstrated by your negative post.
I can think of only twenty or thirty easier ways to accomplish the goal.
Had a neighbor once told me. 'When you get older, you don't get smarter. You just get lazier. You figure out easier ways to do things. And That makes you Look smarter.'
I'm finding that he was NOT wrong. :h:)
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 24, 2026
