- jbc28ExplorerHow much travel can the front axle have before it gets into the driveshaft of the back axle?
- Crazy_CooterExplorer
Securiti wrote:
Here is another pic of driveline to back axle.
Took it out for a drive today. Had a vibration. So now I have to work out the kinks. For the most part. I will not be running with back axle locked in all the time. It probly would bind like a truck in four wheel drive on pavement if i left it lock in all the time.
Are the angles of the rear shaft equal to one another?
Seems like I remember the rear axle pinion pointed at the bed? If so, CV would fix that. - joebedfordNomad III
Crazy Cooter wrote:
It's a fun project but it has no GVWR now.
I have been waiting for the weight police to come here and tell you regardless of the mods you made to your truck, it still has a 10K GVW, so you aren't allowed to drive it cause it's overloaded....... - sljkansasExplorerTugCE may be on to something, maybe a swap from a U-joint to a CV-joint or split shaft (not a carrier bearing).(I'm not sure what they are called) you breaks the shaft into 2 shafts with U-joints on both shafts and a Double yoke between them. similar to sone steering shafts
- TugCEExplorerIt might just be the picture but the angle on the rear axle looks a little high. Do you think that might be the reason for your vibration?
I am glad that you are posting again as I really enjoy reading about your projects. - SecuritiExplorerHere is another pic of driveline to back axle.
Took it out for a drive today. Had a vibration. So now I have to work out the kinks. For the most part. I will not be running with back axle locked in all the time. It probly would bind like a truck in four wheel drive on pavement if i left it lock in all the time. - SecuritiExplorer
Doughboy12 wrote:
@Securiti,
I love your work...
And lest we all forget...Thank you again for your sacrifice!
I know you don't hear it enough.
Thank you. You are right. - jetboater454Explorer
Securiti wrote:
It weighs 11500 now. The hitch is between both axles. Seems to be working.
Wonder what you'll weigh if you have any cash left over to fill the aux tank.:B
Looking good. - Doughboy12Explorer@Securiti,
I love your work...
I know you don't hear it enough. - SecuritiExplorer
Surely that pig has to weigh in well north of 12K unladen right?
Where did you locate the 5er hitch in relation to the axles? I assume it had to be over the rear?
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 19, 2026
