- The_TexanExplorer
Securiti wrote:
Pictures please......LOLTugCE wrote:
Have you done anymore work on the Old Fire Truck?
It is done. Just going threw the process of getting it registered as RV. That way plates will be $82 & anyone with regular licence can drive it. - SecuritiExplorer
It is done. Just going threw the process of getting it registered as RV. That way plates will be $82 & anyone with regular licence can drive it. - TugCEExplorerHave you done anymore work on the Old Fire Truck?
- SecuritiExplorer
BigToe wrote:
Wow... that rig will cost you $36.00 in toll just to cross the bridge around here. ($6.00 per axle).
I have already noticed the increase this year when I took RV out. - BigToeExplorerWow... that rig will cost you $36.00 in toll just to cross the bridge around here. ($6.00 per axle).
- SecuritiExplorer
jbc28 wrote:
Securiti wrote:
jbc28 wrote:
How much travel can the front axle have before it gets into the driveshaft of the back axle?
Not much if u r talking about the space between top shaft and top of ft axle.
How do you plan to deal with that when towing?
It seems that contact could occur when pulling in uneven areas, especially with weight on the rear end.
It Isent a problem rt now. But I do think I am going to redo that design. Maybe relocate the carrier bearing back farther. - jbc28Explorer
It seems that contact could occur when pulling in uneven areas, especially with weight on the rear end. - SecuritiExplorerI worked on it today. And I found that the frunt driveshaft was butted tight against the gearvender. Must of happened during the ajustment of gearbox.That took most of vibration out. I think it is going to work this time. I just have to work out the kinks now.
- SecuritiExplorer
Not much if u r talking about the space between top shaft and top of ft axle. - SecuritiExplorerThe last time I tryed to put this to geather. I spent $350 on getting drive shafts cut. This time I did it myself. Therefore I think I have a Balance problem. When I am sure this is going to work. Then I will take it to a driveline shop to get driveshafts done.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 19, 2026
