CampbellDaycrui's avatar
Oct 17, 2016
Converting Superglide kingpin box to standard type
I've just bought a 5er that has had a Superglide capture plate welded to the kingpin box. My TV has a B&W turnover ball gooseneck hitch already and I intend to add a Companion slider, so I need to get rid of the plate with the big wedge on the underside.
Has anyone ever had to remove and replace a Pullrite capture plate with a standard reinforcing plate? Is it easier or safer to buy a whole new kingpin box instead? BTW, the Superglide plate was welded into place and I am not sure if it was on top of the existing box plate or not.
  • Cut the welds with a cut off wheel or grinder. The original plate will be under it.
  • Superglide capture plates come in 2 version: Universal and Custom
    Universal usually ends up needing welding to complete installation
    Custom by design are typically held in place with set screws.....made to fit specific king pin box
    Is this plate fully welded in place or tack welded in sections.
    Tacked welded can be removed using cutoff wheel in grinder
    Plate just slips over existing king pin plate
    If fully seamed welded........replace box....easier
