LostinAZ's avatar
LostinAZ
Costco Michelin Ribs update
Was able to talk to the local Costco Tire Store manager today to try to get clarification on what the warrantee would be on the Michelin Ribs 235/85 R16 tires for a 5th wheel. No mileage guarantee, No road hazard guarantee but Michelin would replace the tire if a manaufacturing defect showed up. Tire would be replaced on a Pro-rated basis based on tread depth. Would not be allowed to park truck and 5th wheel in Costco parking lot to bring one tire in at a time but would be allowed to park the truck and 5th wheel in the vacant lot next door and bring in one wheel at a time.
Additional information on the 2006 Montana 3400RL Aluminum rims rated a 3,045 lbs. According to information on Montana Owners Club postings these same Aluminum Rims were approved in 2007 for 110 PSI and/or 3750 lb weight carrying capacity. Supposedly the older rims of this type were grandfathered in because no change had been made on these specific rims between 2006 and 2007. At the present time I do not plan to put Goodyear GS614's on this 5th wheel because I think it is overkill with 6,000 lb axles and therefore the issue may be moot. However, if I change my mind I will do considerably more research on the rims capability/reliability at 110 PSI.
This thread is a continuation of the "Freestar Shredded" thread that has been closed by the moderator.
  • I believe the best tires come with no milage warranty. Warrantys are sales gimmicks to move junk. You will most likly replace the tire do to age.
  • RVUSA wrote:
    I wouldnt think of it as putting on an over sized tire, but more of adding a larger safety margin. And considering the damage a tire can do, the larger the safety margin, the lower the risk of damage from a blow out.
    Agree a larger safety margin is NEVER 'overkill'
  • If cost is a concern, don't overlook the Bridgestone Duravis R250 which is very similar to the RIB at about $50 per tire less.
    Chris
