We also have the pull out carrier on our Cougar 327RES and have yet to use it. (which reminds me I need to lubricate it before it rust in the closed position)
It is weight rated with a warning that you need to deduct the spare tire assembly weight from the rating, which will not leave much weight capacity.
My concern would be the extra overhang reducing clearance when coming in and out of various entrances plus the added tail swing. Just something else to monitor.
I would recommend adding additional bike rack hardware should you want to use it for that purpose, but then you would likely compromise the slide in/out function.
In our case I can only see it's use as being as an added outdoor off the ground storage areas when parked i.e. chairs, BBQ etc.
Not sure the added weight is worth the utilitarian gain.
Enjoy GPG
