GHop
Jan 26, 2019Explorer
RollandB wrote:
GHop, did you measure the hub or Axle centers? Reason I ask is I would go more with that measurement.
Ours was 35” with the OEM Dexter equalizer, the CRE3000 that I had put on ours before the SRE4000 was a 35” but moved the spacing to 33”. That’s when I got in touch with Dexter, emailed photos as I was concerned with the change since it brought the tires closer to each other. They involved one of there engineers and couldn’t explain the change they also said I would have 33” based on the hanger spacing.
I installed the 35” SRE4000 and got the spacing back to about 35” as it was before.
If you don’t have wet bolts now, I would suggest getting them with the SRE4000
Good luck with your install!
Thank you for responding. I measured from the center hub to center hub which gave me 35 inches. So with this measurement, I ordered the SRE735
What I have a concern with is the Dexter equalizer is two inches smaller than the MorRyde SRE 4000. Thank you guys for helping with great input.
About Fifth Wheel Group
