memtb
Apr 18, 2019Explorer
sayoung wrote:
I didn't realize how much difference between my 3000's that came on our 5er and the 4000. Our rig also came with the shock mounts but with the axles flipped no body has been able to get me a shock that fits. Not Jayco or LCI, Monroe won't give me a clue either.
Did you do both 4000 & Joyrider at same time ?
We had a shock issue on our 5th wheel after I used the MorRyde system to raise our unit to it’s highest possible position. I took measurements at the shock location ( for all 6 shocks), with the axle at it’s lowest position and at it’s highest at all 6 locations. Once I determined the maximum/ minimum length needed, I went to the Monroe website and searched thru all of the shocks listed to find the one that would work for my application. There are a lot of shocks listed, and a rather tedius procedure to narrow it down!
http://www.monroe.com/downloads/install-instructions-guides/MonroeMountingLengthSpecifications.pdf
About Fifth Wheel Group
