fj12ryder
Jul 04, 2023Explorer III
JMO, but if you've not checked the wheel bearing grease, I wouldn't use the EZ Lube system. And JMO also, I can't see bangs coming from the wheel bearings being low on grease. Could be a brake issue, which is another reason to pull the wheels rather than just pumping in grease. Might need to have someone watch, and listen, while you're backing up to narrow down the location of the bang. Does it bang when you're backing up in a straight line, or more often when you're backing up at an angle?
About Fifth Wheel Group
