Cummins12V98
Jul 05, 2023Explorer III
fj12ryder wrote:
Just to clarify, you can't get too much grease into the axle to blow past the rear seal using the EZ-Lube system and a hand powered grease gun. Excess grease will exit the axle past the grease zerk. If grease gets past the seal, it's a bad seal.
100% agree!!!
Not sure WHY a person needs to spin the wheel VERY SLOW???? I spin away and pump as fast as I can. Goof quality Synthetic grease will flow easily.
First time i would take it apart and clean out old grease and replace the Chicom seals with a US Made seals. Then in the future I would give the tire the push pull test for bearing play and if good pump away!
About Fifth Wheel Group
