The 5th wheel is a Reflection 295RL. It’s definitely one of the 150 series and the 295RL is the only one where the awning runs past the bedroom window. They’re 8800lbs dry with a dry pin weight of 1400lbs. GVWR OF 10,995lbs. We have no idea what is loaded in the trailer. Going by GVWR there could be 2200lbs of pin weight. Totally doable by the right F150. Going strictly by the wheels on the truck it doesn’t have the HDPP. But none of that matters when the pin slides out the back of the hitch. Either way, that is a lot of damage if that’s what truly happened.
