DannyA wrote:
Is anyone using the Curt 5th wheel adapter? Just traded trucks and have a gooseneck ball so was thinking of a way to use it. Just wondering how these adapters work for others. Have a Pro Series hitch that I think would fit on it. Also looked at the Andersen hitch, read some good and bad on it. Biggest problem seemed to be damage to truck bed.
The Curt seems to be a better solution. Think I read Blue Ox makes an adapter also. Any ideas would be appreciated.
I used the Curt X-rail & Curt turn over ball gooseneck hitch until going Andersen and that's what is staying in my truck. .I used both a BW & a Reese on the rails.
Its HEAVY but gives a clean bed when not towing. I don't remember exactly but its capacity is 20K or maybe 22K pounds As said earlier, you must order based on what "turn over ball" you have. The Curt version uses 2 pins & is round shank where BW is square & one pin.
