azjeffh wrote:
I am looking for a new hitch as well. I'm currently considering the Curt Q24 and the Reese Elite.
I have read posts on this forum that some of the Curt hitches can be a bit finicky to connect and disconnect, but once used to the process it's not an issue. Suggest you do a search to gain more info.
Just wait a bit and I'm sure you'll be hearing from the B&W crowd, which from what I have seen is an excellent choice. If they only made a 25K to drop in a Ford with 5th wheel prep :(
Well Ford for 2017 should spread out the pucks in the bed a bit, so you wish should be for a new truck first. Hopefully they will take note of RAM's great puck setup!
On edit: The video of the new 2017 Ford still shows the puck in the bed much closer front to back vs the RAM pucks.
Chris
