jjinatx
May 16, 2019Explorer
CURT Q20 Slop and Noise
Hello,
I'm a fairly new fiver hauler. I have a CURT Q20 and R20 slider combo on my F350 that was installed as part of the deal on the new truck. I've towed a 11,000# Grand Design about 7,000 miles total between many campsites. I religiously maintain the hitch, greasing according to the manual and etrailer's youtube video. I use the teflon plate that came with the hitch. Just about every time I hook up, I spray the jaws and the pin with heavy duty silicon.
I noticed that after stopping, like for a traffic light, when I take off again there is a jolt like the pin has come forward a bit during the stop and is moving back against the jaws on acceleration. Is this normal? Or do I have something to worry about?
Also the hitch is pretty noisy when maneuvering. Lots of clunking. I noticed there is some play between the R20 base and the ISR rails. I can jiggle it slightly up and down. Also, there is some play between the R20 wheels and its base. Again, I can jiggle it up and down a bit. I assume that's the source of the clunking.
When I took delivery of the truck, with hitch installed, there was a plastic bag containing the teflon pad and 2 rubber pads shaped like rectangular donuts. I assume these are pads to go between the ISR and the R20. I also assumed these are just a couple of spares, but maybe they didn't put any pads on the ISR, or just installed 2 of them.
I don't know if I can check without lifting the whole hitch off the ISR with my front end loader. If I go to all that trouble, I may just lift it out completely and swap in a Blue Ox Super Ride and put the CURT on craigslist.
Any advice sincerely appreciated. We're leaving on a jaunt to Alaska soon and want to make sure I won't have any issues on the trip.
-jj
-jj
