jjinatx wrote:
Hello,
When I took delivery of the truck, with hitch installed, there was a plastic bag containing the teflon pad and 2 rubber pads shaped like rectangular donuts. I assume these are pads to go between the ISR and the R20. I also assumed these are just a couple of spares, but maybe they didn't put any pads on the ISR, or just installed 2 of them.
I don't know if I can check without lifting the whole hitch off the ISR with my front end loader. -jj
You should be able to see the rubber pads without lifting if they were installed. Problem with the rubber is it will pound out after some time. I have the Curt non-slider but it is very quite. I solved the problem of slop by getting some thin aluminum/stainless material from Home Depot and cut it to go under the hitch leg and above the hole for the pin. Reread jimnlin response.
