cummins2014
Nov 23, 2021Explorer
RoyF wrote:
I've been hitching up for many years with no problem until this summer.
The hitch head is supposed to be a little higher than the kingpin. But this time, it must have been several inches higher. As I slowly backed into the kingpin the truck was stopped by the pin box, which did not rise up to engage.
I pressed the gas pedal a little with no result. Now the big mistake: I pressed the gas pedal a little bit more. This time, the 2021 F350 (with 1,000 foot-pounds of torque) lurched back and made a very hard impact with the trailer.
The upshot was that both my front jacks and my (brand new) hitch head were damaged. The jacks would operate, but only slowly (the motor was really struggling). The hitch release arm could be pulled out only by rigging up a hydraulic jack. Total cost: more than $1,000.
Don't do what I did. If your pin box does not lift up to engage easily as you are slowly backing then get out and raise the pin box.
I have always been concerned with putting too much pressure on the hitch, and front landing gear when backing in . Usually I would back to just where to the two meet ,and then adjust accordingly , putting very little pressure on that hitch if any. I think the idea of pushing down on the hitch forcing the truck down a bit was to prevent high hitching . I never cared for that idea. I can certainly see if I had high hitched .
Now with the Andersen ,no worries with damaging a hitch or landing gear .
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 19, 2026
