allen8106
Jul 01, 2019Explorer
I could be wrong but the PSI rating should be stamped separately from the wheel info. Also based on what I've seen the codes should look more like this: 7J x 16 H2 5/120 ET47.
7=rim width
J=bead profile
x=one piece construction
16=rim diameter
H2=flange type
5/120=bolt pattern (5 bolt/120mm diameter pattern)
ET47=offset distance between center line of wheel and plane of mounting hub
I believe the limiting factor on any wheel is load capacity, not pressure.
7=rim width
J=bead profile
16=rim diameter
H2=flange type
About Fifth Wheel Group
