ashlandrv's avatar
ashlandrv
Dead Battery? No lights working
Hi there. I have a 2003 Cougar Fifth Wheel. I was using a space heater and it kicked out my breaker. I reset the breaker box outside, I reset the breaker panel in my fifth wheel. I reset the GFI. However, I'm still having no power from the batteries or 12V system. All my power outlets work, but most of my interior lights don't work, the fridge has no power, my level reader has no power. What can I do to fix this? What else do I need to reset, and how do I do it? Please help! Thank you!
  • RoyB's avatar
    RoyB
    Explorer II
    Looks like you have two posts with the same problem... I answered the other one haha...
  • I have never had that problem, but read on a thread a couple days ago about a similar problem and poster was told to check the switch or switches on the converter. Hope this helps.
  • Check the 12 volt fuses in the converter panel...you'll need a test light or volt meter to do this. Also check the main fuses near the battery the same way...I'm guessing it is a more likely one of the fuses in the converter panel...good luck
