RVweekends's avatar
RVweekends
Dead flies in Fantastic Fans
I need suggestions on how to get dead flies out from behind the screens on our Fantastic Fans. Am I missing an easy way to get behind the screens? We had a lot of flies get in our RV when the weather started getting cold last fall. Not sure where they are getting in, hope it doesn't start again when weather gets a little warmer. The black tanks do not smell either, they were flushed. We usually put our camper in a hoop shed for winter, but this time it has been left in our driveway.
  • Buy a set of Fan-Tastic Vent's 'POP-N-LOCK' snap in screens
    Remove your screwed on screens and replace with the snap in screens
    Then cleaning is so much easier
    POP-N-LOCK Screens
  • With the vent opened- Turn the fans on high exhaust and tap the screens to loosen the flies.
    Or use an air compressor and blow the flies off of the screens with the vents opened.
    Or tow the 5th wheel down the highway with the vent covers opened the pressure difference will suck clean the screens.
