Denny & Jami wrote:
rjsurfer wrote:
Denny,
I have the same thought about painting the decals. What paint are you going to use and how are you going to edge it? I'm thinking the painters blue tape won't bend enough for all the curves I have.
Thanks
Ron W.
I'm using base coat clear coat paint with a sealer underneath, I have a friend that has a body shop with his own mixing station. I bought some Scotch 233+ tape from him and it works great, good clean lines and it will bend to a point, really tight turns I'm using a 1/4" vinyl tape, I'm also using a Scotch Bright A very fine scuff pad to prep the surface between the tape. I have one color done and plan on the second color Friday.
Denny
Denny,
Thanks for the info. I don't have access to auto paint, will go with rattle can. What would be the best finish gloss, semi-gloss or flat in your opinion?
Thanks again
Ron W.
