laknox wrote:
Alannyiri wrote:
ford truck guy wrote:
You stated that you will have a small car with you for the running around..... Will you be double towing with the truck?? No brainer if double towing.... diesel.... BTW - I would do diesel either way... I moved from the V-10 to the diesel and will never go back....
No, thanks, we won't be double towing the car - my wife will drive behind, or scout ahead.
Well, you could go for an M2 Freightliner with a Smart car loader between the cab and pin and not have to drive separately or tow doubles. :-) http://www.mountainmaster.net/smartcarloaders.html
Lyle
Yikes Lyle!
UNDERkill on the high dollar MDT compared to an HDT, and
OVERkill on the high dollar Smart loader!..:S
HDT folks loading Smarts with winch and simple ramps.
UNloading = drive off.
Some drive them up as well.
Some folks carrying jeeps on the decks - but of course, can't be loaded sideways. Loaded from the rear with ramps.
Usually not singled (retain tandem axles).
BTW - (OP) compared to the deck options, "following" behind is a PITA..:W
