cummins2014
Nov 09, 2019Explorer
Cummins12V98 wrote:Cummins12V98 wrote:
There are hitching issues with the PullRite, not sure if that's the case with the Demco???
I think MeAgain should comment on the B&W as he has one.
It does not matter who owns a manual slider. One they are heavy, two they are MANUAL, I have had a manual slider for 14 years. I know exactly what they are about ,brand makes no difference , you have to get out if you are in a situation where you have to use it, and pull the lever ,slide the hitch back. After that they have to be returned to the tow position before towing again.
Simply put they are pain , no way getting around it . As said no more manuals . Andersen has solved all those issues . I seen enough problems with hitching with my friends Superglide ,and the fact you CANNOT hitch at a certain angle. No thanks ,I want to come into a hitch at whatever angle I need too within reason .
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
