laknox
Nov 10, 2019Nomad
jodeb720 wrote:
I recently replaced my Truck and decided it's time to upgrade my hitch at the same time.
I've narrowed my decision down to two Hitches. Demco Autoslide or B&W Companion slider.
One of my biggest complaints in my old receiver was the lack of lateral gimble from side to side.
The B&W seems to have almost no side to side movement - where as the Demco seems to have enough to align the pin to jaws without binding.
Any thoughts on either? I know the Demco I have to adjust the side guide bars each time I connect to the 5er - but that extra work will be worth it because of the lateral gimble.
Thanks!
josh
Replying without reading ahead...
Apples and oranges. Auto-slider vs manual. Also, you give no info on what the new truck is. I will always recommend B&W, because it's what I have and my experience with my hitch and with B&W as a company tells me that they're one of the best products and companies around.
Just remember that no matter =what= hitch you get, you =can= still hit your cab when backing up. A slider only gives you a bit more time/room before you =do= hit.
Lyle
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
