Cummins12V98 wrote:
Also all B&W hitches have a lifetime warranty. Also they are easy to hitch and unhitch even with RV and TV at different angles. Also they can be locked so some idiot can't pull your latching handle pin and cause the RV to drop.
I can concur on all of these points. I've hooked up at different angles - just be careful that your tailgate doesn't hit. You can easily see when the jaws are correctly locked around the king pin, and you can lock them. Only con is that it is heavy. I had to get two people to help load it in.
