pcm1959
Oct 21, 2016Explorer II
We have Never Lube with 8k axles and Dexter disc on our 2014 fiver. We have about 9k miles on the rig. I check the temps with an infrared gun periodically and check for end play when the wheels are off the ground. Dexter recommends doing this check at least every 12k miles and to check the hub caps for excessive grease leaking from the cap seals.
Dexter also says that the wheel should turn freely and quietly when off the ground. That part I find difficult to absorb as each of my wheels turn differently as far as freely is concerned. I attribute that to brake shoe drag. I guess that's normal?
On the subject of oil bath bearings, I have always heard that they offer superior lubrication for wheels in motion. However, they are not recommended for vehicles that set for extended period of time.
About Fifth Wheel Group
