mbrower
Oct 22, 2016Explorer II
AniJet wrote:Denny & Jami wrote:
Were your original axle Dexter or Lipert, if they were Lipert that was your problem not Never-R-Lube thats a Dexter product. lipert made their own and it was failure. Denny
They were Kodiak hubs on Alko axles. You are correct that Nev-R-Lube is a Dexter name but they both use the same 50mm bearing cartridge. Lippert has never made bearings, they source them from other vendors as does Dexter.
This is true but as I understand, incorrect offset of the wheels provided by RV/axel manufacturers was a major cause of bearing failure. Dexter as I understand always warned against using wheels with any offset. Not an expert but this is what I read/learned from research when I found out my RV came with never-lube bearings.
About Fifth Wheel Group
