Denny___Jami
Oct 22, 2016Explorer
AniJet wrote:Denny & Jami wrote:
Were your original axle Dexter or Lipert, if they were Lipert that was your problem not Never-R-Lube thats a Dexter product. lipert made their own and it was failure. Denny
They were Kodiak hubs on Alko axles. You are correct that Nev-R-Lube is a Dexter name but they both use the same 50mm bearing cartridge. Lippert has never made bearings, they source them from other vendors as does Dexter.
Its the design of the hub that can make a difference, the center of the bearing has to be centered on the weight bearing part of the hub. The same goes for the wheels they have to have 0 offset with Nev-R-Lube bearing where standard bearings with take a offset to a point.
Denny
About Fifth Wheel Group
