snowpeke wrote:
My Jayco has E Z lube bearings. The Dexter has a you tube video and shows that you pump grease in until the new grease comes out. I called a Jayco dealer and he says not to do it that way. Says that grease gets in to the brake drums. Witch way do I go?
What I do, and this is experience from decades as a farmer and greasing all kinds of stuff, is to jack each wheel up and add grease until you start to hear small popping sounds, while spinning the wheel. This is air being forced past the seal; grease will follow shortly behind that. I always give it 3-4 more shots after I start to hear the popping. This means that it needs to be =quiet= while you're greasing, so turn the radio down or take your ear buds out. :B
Lyle
