BarneyS wrote:
I agree with the recommended procedure as described in this link.
I had those types of bearings in my previous trailer and had no problems in many years of towing using the same procedure.
The trailer in my signature has the "never lube" bearings, which are a cartridge type and they have never needed any service in over 15 years of travel. :)
Barney
Makes me feel better Barney. My fiver has 8k 50mm NevRlube bearings. So many really poo poo them but I have heard the 50mm are ok provided used with the prescribed zero offset wheels. I figure they must be reliable bearings since New Horizons installs them standard.
I used to use the EZ lube on my former Carriage. I'd lay the grease gun in the sun and also tried to do the job when the ambient air temps was warm or after towing. Anything to get the grease to flow better. Turn the wheel and slowly pump the grease. Good luck and safe travels.
