broark01
Mar 17, 2014Explorer II
I have Dexter EZ Lube, not a big deal pulling, one lock ring, one nut and should slide right off. I replaced all brakes from backing plate out and all bearings and races. If you do pull the hubs, might want to have at least new seals to put back in. You might or might not discover grease on your drum brake pads which then means new brake pads and cleaning hub and other stuff.
If you galled the lugs might want to think about some help :-)
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
