garyp4951
Jun 02, 2017Explorer III
azdryheat wrote:
Frankly, I see no reason to fill up the hub with grease. Too easy to blow grease past the inner seal and contaminate the hub and brake linings. I too have the EZ lube axles but I don't pump in the grease. I grease the bearings, re-install them, and nothing more.
X2, I see no reason to put a tube of grease on two bearings except in marine use. You need to inspect your bearings, and races, and this can only be done by cleaning , and re packing.
About Fifth Wheel Group
