Luke_Porter
Jun 05, 2017Explorer
Likes to tow wrote:
To all of you still using the EZ Lube feature on your axle be aware of the issues with this system!! If you have been pumping away with your grease gun and nothing comes out there is the possibility that the rear seal has blown out and your are lubing your brake shoes and magnet assemblies. I highly recommend you pull your brake drums and inspect for grease on the brakes~!!! There are significant amounts of opinions on using the easy lube system but most experienced Rv'ers will only hand pack the bearings. Easy Lube is wonderful for boat trailers that get submerged in water but useless on any trailer with brake actuators operating on the highway. Do a search on this and other forums about this issue and you will find an overwhelming number of people have had major issues with grease on their brakes. Look at the Grand Design owners forum and see the issue with Lippert and the massive replacement of complete brake assemblies due to grease getting past the seal.
I agree with this guy. If you do fill the whole thing with grease and down the road you pull it off and clean out all of the grease---I doubt you will pump grease in again.
About Fifth Wheel Group
