- Jerry_BExplorerI bought a ramp rated for 15K lbs. It collapsed under the weight of my Mobile Suites. There goes $60.
- NHIrishExplorerToo much weight on one tire. You might be fine, and you might not be fine somewhere down the line. I would avoid doing it.
- Jerry_BExplorerThanks guys for the come backs on the brake adjusters and tire ramp.
- USAFBILLExplorer
Jerry B wrote:
What do you think of running one wheel up a ramp lifting the other wheel off the ground? Too much weight on the single wheel?
I have always done them this way without any problems - Jerry_BExplorerWhat do you think of running one wheel up a ramp lifting the other wheel off the ground? Too much weight on the single wheel?
- dbblsExplorerThey will adjust either direction but it is faster in reverse. I would not worry about adjusting the one wheel. It will get adjusted, just drive it.
- Jerry_BExplorerI have one brake that I had to back off the adjuster to get the hub off. When I jack up the axle under the spring pad/shackle, I can't get to the adjuster wheel. So what I have here is three wheels adjusted up and one not. Any problem or will the one wheel adjust up in quick order?
- allen8106ExplorerBoth
About Fifth Wheel Group
