Espee
Jan 11, 2014Explorer
Diagnosing Lippert Frame issue with my Cougar
Read lots of posts about similar issue with the front cross member splitting on my frame. I have the cabinets getting torn apart similar to pics I have seen in these threads, so suspecting the same cross member issue as others here have had to deal with. After removing the lower shroud under the bedroom to inspect the framing, I am unable to find any broken welds or splitting of the beams / cross members, but something has to be causing the damage to my closets... if the beam was splitting, wouldn't I be able to view it from below?
Is my frame just flexing more and more now days, and it is just a matter of time until it finally splits and cracks thereby tearing apart the welds etc? If I reinforce the front cross member now, will it solve my cabinet issue? Next step is to pull up the flooring to inspect from above, but wanted some feedback from others before I go to all the trouble. Any feedback would be appreciated.
Here are a few pics of the current damage that I have tried to repair, but keeps getting ripped apart each time. It seems it is getting worse and I see at least an inch of movement between the hitch and the front cap on bouncy roads...
