So, I noticed that KZ totally cheaped out on the front roof-to-cap seam on my '17 Durango 1500. Silicon bead along the seam, covered by a 1+" wide seam of Dicor, EXCEPT for a gap of 3-4" at each end,...
Permanent means when you stick eternabond down it’s down. If you need to repair something in that area trying to remove the eternabond will most likely make matters worse. Self leveling dicor is just the only ??way to go.
