Dayle1
Jul 26, 2017Explorer II
ChuckV1 wrote:
I'm not going to go over weights, it's been done as you have read a number of times, all I will say is think about safety.
At 45 or 50mpg can you stop your truck an trailer within safe limits, ie think about the weight that's pushing you down the road, then someone brakes in front of you, can you stop before hitting them ...
That is why people move up to bigger TV, not only to handle the weight but the stopping power, it's for the safety of your family along with others on the HWY . Can your truck pull the trailer, yes without a problem, but can it stop your trailer in an emergency stop is the real ????
Safe travels
Truck brakes stop the truck (which includes pin weight), but the fiver axles have brakes rated to stop the same weight they can carry. No trailer should be pushing the tow vehicle, sure way to loose steering control. Proper brake controller setup and brake maintenance are critical. Sure, my 3500 has bigger brakes than a 1500 truck, but last time I checked the published UNLOADED stopping distances were about the same. So there is not excess braking capacity available for stopping the trailer.
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 25, 2026
