- taybrynnExplorer2006 gmc sierra 3500 dually (lbz duramax) pulling a 39' wildcat 5er ... Avg around 12 mpg .... Not towing around 17-18 not chipped
- RVERExplorerI tow a 35 ft Sunnybrook fiver with a Silverado 2500 diesel with duramax engine and Allison transmission and cannot do anything but highly recommend it!! I get 13.5at best MPG going to Maine from Massachusetts, but going to Rhode Island I get about 12.5 (go figure) The most important is to get a truck that will pull your trailer EASILY so the smallest I would get is the 250/2500 model and not the 150/1500 models. Always have more than what you need. Make sure you are comfortable for hours in the seat, that the GAWR and GCWR and GWR are all well within your needs. Do not let any dealer talk you into a truck that is maxed out with a trailer loaded up with stuff and you and whomever else in the truck.
- larry_barnhartExplorerI need to tow at least 60 mph for our best mileage, 62 is the best.
chevman - Cummins12V98Explorer III
jmilner wrote:
I have a 2005 Duramax 6.6. just pulled a 30ft fifth wheel . Total weight just under 21000 lbs and got 11.5 pulling and 16 to 21 without.
Those sound like honest hand calc numbers! - AllworthExplorer II2006 Duramax/Allison. Just got back from 1800 miles into the Smokeys and back with a 12,750 trailer, wife, grandson, dog, and junk.
10.1 towing (63mph max).
17.4 solo.
10.9 total. - jmilnerExplorerI have a 2005 Duramax 6.6. just pulled a 30ft fifth wheel . Total weight just under 21000 lbs and got 11.5 pulling and 16 to 21 without.
- sdetweilExplorer
jim summers wrote:
... Also I'm baffled/troubled by
DEF. I don't have it now & read bad tales about it. Thnx
can't answer the truck questions.
on DEF they discovered if they spray some fluid with the right properties into the hot exhaust after the filter, it will combine with the remaining nitrous oxide (bad) and turn into water and nitrogen (good). doing this means they can run leaner (better mileage, less soot)
DEF Diesel Exhaust Fluid is that formula that works. Urea solution made with 32.5% high-purity urea (AUS 32) and 67.5% deionized water.
I use about 2.5 gals/4000 miles. a little more when towing.
I buy a spare 2.5 gal jug when I see them on sale. Last year towing at a truck stop, it was 2 2.5 gal tanks for $20. (instead of $15 each).
sometimes fill up the def tank at truck stops cause they have a nozzle and cheaper price. (~2.50 gallon) - RedRamExplorerOn my 04.5 Dodge I can honestly say I get between 9.8 and 10.2 when towing the 5'er in my sig.Empty it usually stays around 18 mpg and I don't get in a big hurry and the truck doesn't have any chips or engine upgrades.
- jim_summersExplorerMy 2003 D'max has 90m miles on it. It sits idle half of each yr. when we
Lv AK & travel we tow a Nash 25r (10000lbs loaded). I drive at 59-61
Mph. That's when my D'max shifts into the highest gear at 1650 rpm.
That's w/ " tow/haul" also. I get an honest (pencil & paper) 12 mpg towing & 21-22 empty when we're Just touristing around. I'm looking at a new 2015 D'max. Anyone tow this slow Except me? What do new D'Maxs get at the slowest speed
Shifting into the highest gear while towing? Also I'm baffled/troubled by
DEF. I don't have it now & read bad tales about it. Thnx - laknoxNomad
NC Hauler wrote:
laknox wrote:
NC Hauler wrote:
laknox wrote:
Vulcaneer wrote:
Not sure I agree with everything that travelnutz has posted. But I do agree that the old Dodges and Rams I see here in the NorthEast do seem to not tolerate road salt well. Look at those that are 2006 and older, and their bodies, frames, do not hold up as well as the Bodies and frames on the Fords, or GM twins. On all makes of that age, the brake and fuel lines are either replaced, or need to be replaced.
Of course the Ford 6L, have other devastating problems. But they seem to hold up against the salt better than the RAMS/Dodges.
So considering that, if I was going to recommend a diesel of that vintage, it would be the GMC, or Chevy. The 2006 or 07. are very good models.
Just my opinion.
Also, if you stay to the early '07 Duramax, you don't have to deal with DEF, IIRC. I know that if I can replace my current '02, and I have the funds to play with, I'd =build= an '06 or early '07, with beefed up frame and current undercarriage to get the payload of the '14/15 trucks. It also would get registered as that model year, no matter what's "under the hood". :-)
Lyle
Don't think DEF came out till 2010...believe you meant DPF which came out about the middle of 07.5, (EGR before that).
OK; whatever the extra cr@p you have to put in. I still find it somewhat amazing that the world's largest diesel engines, with 100,000+ cubic inches PER CYLINDER, are also the most efficient IC engines ever built for production =and= meet all current international pollution standards...running on heavy fuel oil. Why can't we do this with these puny engines so we don't have to have special fuel additives?
Lyle
Hey Lyle, I'm on your side..agree 100%, but I don't use any fuel additives....DEF isn't a fuel additive...wish we didn't have it, just like DPF or EGR, but guess if one wants a newer diesel, they'll have to get the EPA emissions that come on it...
I think OP is looking for an 05, which will keep him out of DPF, DEF and if not mistaken, the EGR, though it may have come out in 05...can't remember at this time.
My desire would be to =build= a truck on an early 2007 chassis, so no pollution junk and I could put a beefed up frame and an updated suspension under it with the most modern engine and transmission. Registration wouldn't be much more than my '02 D'max. :-)
Lyle
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
