- goducks10Explorer
BB_TX wrote:
You click on advanced post form below. When that opens there is an icon (labeled link if you move your cursor over it) to click on. You put in the url, give it a name, and click finished.
The same form will open if you quote someone.
And 'Reply to topic" - BB_TXNomadYou click on advanced post form below. When that opens there is an icon (labeled link if you move your cursor over it) to click on. You put in the url, give it a name, and click finished.
The same form will open if you quote someone. - 2oldmanExplorer II
BillB3857 wrote:
Quote his post to see code.
Thanks, Russ. How do you make a link like that. Edjumicate me, please! - BillB3857ExplorerThanks, Russ. How do you make a link like that. Edjumicate me, please!
- JIMNLINExplorer III
Texas Two Steppers wrote:
Could someone who knows explain to me if there are different forces acting on the front axle as compared to the rear and if so what causes the difference. I am speaking of a heavy fiver with the equalizer system between the tires.
Both axle are subject to the same side scrubbing issues while moving around a corner or side loading from strong side winds at highway speeds.
The front axle/stub/wheel/tire can be more prone to damage when impacting a curb while pulling the trailer around a corner.
Braking rotational forces from the rear axle brakes tends to lift the front axle during hard braking events, enough to flat spot the front axle tires depending on how aggressive the brakes are set or poorly maintained brakes (ie. leaking grease seal/worn brake lining/etc)
I'm sure others have their own experiences for more input. - BillB3857ExplorerAlthough this video was produced by Keystone and talks about lug nut torque, it shows graphically what happens to the tires when pulling a trailer with tandem axles.
http://www.youtube.com/watch?v=NpOWLMA2NpE
Hope this helps.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
