Dog Folks wrote:
With two Direct receivers you can watch any program, within your subscription, at any location in the RV, without limitation.
Hope this helps.
With two DISH receivers you can watch any program, within your subscription, at any location in the RV, without limitation.
Hope this helps!
The truth is - Go to Camping World website and look at antenna choices. Pay very careful attention to SD/HD fine print for each dish. Dish people, me for example, are very happy - same goes for Direct. If you want HD, then I think Dish has the advantage with an easier and cheaper dish. If you want SD, then I believe Direct has the advantage, same reason.
Don't pay any attention to the eastern vs. western arc Dish sats. If you truly understand what Dish is doing, it is a huge plus as it gives you more options around trees as to the direction of aim. And you can get all stations off either the eastern or western arcs.
