ETCrockett
Oct 28, 2017Explorer
I had a similar issues first time I tried to use my satelite on our Jayco. If you have two TVs that are connected to separate receivers, does the other TV receive signal? This will tell you whether the issue is between the splitter in the basement and the receiver or the splitter. You have already ruled out the connection at the dish by running the cable in the window directly to the receiver.
My issue turned out to be the connection of the cable behind the connector plate where you connect the cable from receiver to satellite. The connector in the wall plate was not tightly attached. When the cable was connected from the receiver side, it backed the cable off on the back side of the plate. The result no connection to dish.
I hope this helps! Good luck!
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
