enblethen
Oct 28, 2017Nomad
Test each cable to insure they are marked correctly.
This can be done with an Ohm meter. Connect meter between center pin and outer metallic area.
I am thinking that they are marked incorrectly.
The satellite cannot have any splitters or other devices. it must run directly to the receiver.
Verify that the satellite does not go to the antenna power supply. If it does some will work with antenna power booster switch off.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
