Me_Again
Oct 28, 2017Explorer III
Only True Mosnowman wrote:
So something is not working for me. I am getting a Signal 775 trouble communicating with dish. I have 3 connections in the outside command center. 1 for cable..2 different ones that both say satellite.
First question is which satellite connection to use? Bottom one or the one in the middle? ( I have tried all 3 with no results)
Second I am only trying to get it to work in living room. The wall socket says cable for one connection and satellite for the second. ( I have tried both with no results)
So I ran the cable directly from dish into a window and connected to reciever. Works fine.
So I have a wiring problem somewhere and have no idea what to do next???
I am experienced dealing with satellites tailgating and RVing and know it is something in the new RV. There is no green light button in the living room outlet and I turned the green light off in the bedroom with no results. Thoughts?
Like others have posted, we need more information to help you. To fix this yourself you might have to buy a coax cable tester.
RV manufacturers tend to be coax challenged on connectors, installations, labeling and proper tighten of connections.
Chris
https://www.amazon.com/Klein-Tools-VDV512-058-Explorer-Tester/dp/B004CHVOBG/ref=sr_1_9?ie=UTF8&qid=1509204417&sr=8-9&keywords=coax+cable+tester+tracer
About Fifth Wheel Group
19,006 PostsLatest Activity: Feb 18, 2025
